Corsair AX 860i enough?
Axi's are manafactured by Flextronic, the AX line is Seasonic.
There you go! i knew it was something along those lines!
EVGA SuperNOVA G2 is 80 Plus Gold Rated $199 Aus
Seasonic X-850 80Plus Gold 850W $259 Aus
Seasonic XP-860 Platinum 860W Power Supply V2 $299 Aus
Antec High Current Pro Platinum 850W $299 Aus
Corsair AX860 Platinum Power Supply $289 Aus
Corsair AX860i Platinum Power Supply $319 Aus
Dice to me the Evga seems to cheap. I'd expect it to be $50 more expensive. especially if its as good as these other top brands.
Your paying less for the EVGA one as it's not platinum rated and with Seasonic your mainly paying for the name as it's a long established and reliable brand.
If there were a decent 1000W platinum Seasonic PSU, I'd snap that that up. Was interested in the Seasonic ss-1200XP3 but heard there have been issues with the model and there's been a recall.
Yea i realised that its not platinum. couldn't find one that was. i just used them as an example of how all the brands are around a similar price for the same Rating. yet the price between the EVGA and Seasonic is substantial for comparable models. i should of explained my last post better, sorry.
Seasonic XP-1050 Platinum 1050W Power Supply $319 Aus
or
Seasonic X-1050 80Plus Gold 1050W $279 Aus
or
If you have the choice consider Superflower, As I said before there's a reason the pros go with them over Seasonic, Corsair etc...
