TheUnkn0wn
So I've got my mind set on a 350D build, but unfortunately the 350D only comes in black. So after doing some research I've decided that PlastiDip would be a very good solution to that problem since if I don't like it I can just peel it off and I don't need to sand, prime or use different paints . I've made a quick (and I mean quick) mock up of what I'm thinking of using photoshop.
What do you think?
Has anyone tried PlastiDip before and had any problems?
What do you think?
