GamerNexus really attacked MSI for their heatshield for M'2 drives.
Anyway basically when they get hot they throttle and I have an awful Aorus 1080ti that produces heat on the backplate just below the M.2 slot. So I put my M.2 drive in the bottom slot on the motherboard and just by 3x120 mm intake fans to produce enough airflow to keep cool.
May be getting Rog Hero X mb and it has a bracket to enable small fan on the bottom but as can be seen on the Hero IX the bracket can make using the connections below a big problem. Maybe on the Hero X it would have fixed this
Maybe just put a fan on the floor of my 780T and that will get more then enough air flow over the M.2 drive.
any other suggestions for cooling M.2 ...maybe wont need it as I wont push it enough
