Cooler Master Use Nutella as Thermal Compound?
WYP
News Guru
You can use Nutella as thermal Compound? Well Cooler Master have recently gave it a try, with surprisingly good results. Do you want your CPU to be both cool and delicious?
Read more on Cooler Master using Nutella as thermal Compound here.
Your spelling is a little bit off "Cooler Master have recently gave it a try"
You speak good England much win long time ^_^
Edit given in instead of gave and it will look a lot better.
Also whoever decided to report on this originally must be fishing for dregs because this was originally done about 1-2 years ago.
I'm pretty sure this has been done before? Some tech reviewers did a huge test with many different kinds of cooling paste, but also nutalla, butter, mayonaise and all that stuff.
That said; What's up with the internet's obsessions with Nutella? Is it a cool thing to like chocolate now? It's really not that special
Edit; Ah, found the graph. Wasn't Nutella but normal chocolate. Did include mayonaise, lipstick and toothpaste too :p
Full graph and results here.
