Cooler master Enforcer WC log
blair
Hi this is the start of my water cooling log:
Parts
1x XSPC Rasa 750 RS360
1x 4 pin - 2x 4pin
3x 3pin extensions
2x 1L of Fesser one UV Blue
2x Apache Fans (yes 2 youll know why soon)
1x Hose cutter
2x 90 Degree Compressions
1x Mx-4 TIM
Will all be arriving tomorrow so i will post pics of parts and then pic during and after completion.
Looking forward to the pics
Ugly isnt it
Pics at 1.43v and 4Ghz my cpu gets to 55C after 30mins of prime isnt this high? i was at 1.48v at 4Ghz on a antec 620 and only got to 65C
Idle temps are 36C.
Looks ok
Idle temp seems a bit high, not sure what temps you should be getting but a 10*c drop on load ain't to bad.
load dropped 7C now just i had my fan profile to 100% fans at 55C so when it reached 55C 1000% fan then temp dropped fans went down then temp went up in a cycle leaving it around 55C.
idle on my antec was around 43C
