contact probs
ahhhhhh :P stupid me (i did wonder how prommie fitted in a shuttle case) i just presumed :P
What setting do you have the fans that cool the cooler (cant remember wot its called as im tired and its getting late :P) set too? maybe its not getting cold enuff itself which is reflecting on why you have higher temps?
I know that I have got higher FSB and its been OK.. but have never run prime95
how would I get better mem timings???
I want to get better timings.
well u see those settings at "auto" you shud be able to change them to numbers yourself, im not sure how tight u can make your settings as i know nothing about ure ram, start at cas 2,3,3,6 and go from therem that usually works with most decent ram.
name='aXeR' said:
warlord, wot mobo you got, is it an abit? ive heard they are a bit inacurate with their temp reading (wether this is fact or not i dunno) but the -29 mbm shows seems more feasable, i never pay much attention to wot the mobo says
ye sorry i took so long mate. its a p4c800 deluxe. im gonna try again 2day wen i get bk from work. but atm im gettin -15 in bios at 3.6gig @ 1.7volts
if youre having probs getting your fsb higher just disable the last two options of the game acceperator :).
if not experiment with these options and youll see your mem scores go high :)
yes its all those settings that you posted...they call them game accelerator settings...
just disable the last two of them and see if you can go higher fsb wise :)
Epicurus, did you manage to get your temps down? I am seeing -22c idle here but 0c under full load with prime95 and +6c with the case side on. The chip is a P4 Prescott 3.2ghz @ 4ghz (1.4vcore). Not sure what to do now, I've already tried reseating. Evap temp is at -46c....
i use motherboard monitor to monitor temps.
with my barton 2500+ running at 1.8v 2.640Ghz idle -18 full load -7 full load with my st and running at 2.2ghz at default 1.65v idle -26.
I had a prob with the thing that is meant to protect smd components ware it moved while i was mounting the head so that i couldnt start up. and i acidently used standard thermal compund instead of the silver that came with it :p
