In the past I've thought that I'd only stick with clear liquids after hearing all the bad things about colored coolants and dyes. Now I have a situation were I want color, but don't think colored tubing will look as good as colored liquid.
Problem is I know nothing about this. The health of the loop is a high priority and seems like mayhems would be the way to go, but I have some very basic questions that need answering first.
1) With dyes you get what ever color you want, but are there any downsides to them when compaired to premix liquids or is premix just an idiot proof solution? (mayhems dye vs mayhems X1 premix)
2) How will using these vs clear liquid affect rads and blocks and their maintenance? (affect on tubing doesn't matter)
3) Will these stain clear acrylic reservoirs at all?
4) Is there a solution where I just change the liquid every X months and I won't have to worry about any of this and if so how short is this time period?
5)Mayhems vs others, should I just stick with mayhems or are there other brands I would have any point in considering?
