S_I_N
ok so I have a chance to grab a 3930K and Gigabyte GA-X79-UD3 and wondering what the trolls err I mean masses think of it versus my current rig. Those will be the only 2 parts changed out, rest will remain the same.
Current Specs
i7 2600K OC'd 4.5@ 1.36
Gigabyte GA-Z68X-UD7
4x4Gb Crucial Ballistic Elites 1866
H.I.S. 7970 Flashed Ghz bios reference design cards (release day cards)
2X Kingston Hyper X 3K 240Gb ssd's in Raid 0
1TB HDD Seagate or WD (changes from time to time lol)
Corsair AX850 psu
custom water cooled via 420mm and 280mm rad sporting 140mm Blue led Spectre Pro's in push pull.
Wrapped neatly in a Switch 810 case (however this will change once Phanteks releases the Enthoo Primo)
Now I know the socket 2011 takes different mounting than 1155 but my block came with the 2011 stuff as well. Also I know the 3930K will run hotter and consume more power, power draw being a non issue with the Enthoo Primo I can add in another 420mm or 28mm rad and most likely will. Rig is mainly for gaming and internet stuff but one never knows if and when the video making bug hits.
anywho whats y'all thoughts on the matter.
Current Specs
Corsair AX850 psu
