Hey all
the shop I work at just isn't coping with workload.
problems I find is that the booking in system is mainly paper based and then duplicated onto the computer. work sheets are paper based and then copied onto the invoice which is electronic and then paper based. we also have notepads for note taking (URGGHH!) which get lost and pages get turned over etc.
people are also ringing up to check on job status and its all a bit of a inefficient mess at the moment.
so I am on the hunt for a repairs management system that will make everything much more efficient. I am sure the boss will still want to carry on invoicing using sage but the rest of it as far as I am concerned needs to be updated, streamlined and modern.
there are a lot out there, just looking for personal recommendations really - needs to be easy to use, quick and efficient and not just a gimmick
some features I have seen on http://pcrepairtracker.com/ that i like are being able to print at dymo labels linked to that job that can be scanned with an optical scanner along with customers being able to check up on job status and be sent an SMS when we want to
