Compiz everyones favorite eyecandy on GNU systems has just release its 0.60 increment
[Source]
EXCERPT FROM RELEASE said:WHAT'S NEW SINCE 0.4.0
Better support for multiple X-screens.
XML-based meta-data system for handling of various kinds
for meta-data like plugin descriptions, default option
values, etc.
Major improvements to option initialization based on the
new meta-data system.
Extensible logging framework.
Plugin plugins that make it possible to adjust and extend
the behavior of existing plugins through new plugins.
More dynamic handling of output devices, which allows the
output device configuration used when rendering to be
changed between frames.
Cube plugin additions:
* Transparency support.
* Basic background support.
* Support for non-power-of-two skydome textures.
Introspection support in dbus plugin.
Multiple modes of resize drawing in resize plugin.
Multiple placement modes in place plugin.
New Plugins:
* Glib plugin that allows plugins that use the glib main loop to integrate properly with the compiz main loop without waking up periodically to check for pending events.
* Ini plugin: Flat file configuration backend.
* Fs plugin: FUSE plugin that maps compiz options to a file-system and allow efficient manipulation of options by reading and writing files.
* Video plugin: Plugin that provides a composited video interface for efficient video playback.
gtk-window-decorator:
* Support for configurable button layout in metacity themes.
* Support for configuration of middle and right mouse button actions.
* Support for mouse wheel scroll actions (currently window shading is supported)
kde-window-decorator:
* Added UTF-8 support for window titles.
* Fixed display of maximized windows.
[Source]
