CM 690 II Advanced Roof Fans
Funny.Fuka
hello all,
i have a cm 690 II advanced case with the noctua NH-U12P SE2 cpu cooler, 1 rear noctua NF-S12B FLX fan that exhausts, i want your thoughts for 2 noctua roof fans, the roof fans can use either be 120 or 140mm, should i use 2 NF-P14 FLX or 2 NF-S12B FLX fans. i will be using the LNA adapters because i like a quiet rig.thanks in advance
I would get Scythe Gentle Typhoon 1450RPM. I've got a pair of 1850RPM ones and they're incredible, mass air pressure, air movement and with silence.
go for 140's then fella the ones noctua do,they are the best ATM
u want higher pressure for getting the air through the smaller holes in the roof as opose to the bigger ones at the back/front and side of a case
run at 12v aswell
run at 12v aswell
cheers m8 thanks for the info
