Clean Windows 7 install on SSD
LiamTheBoss
Hi guys i want to reinstall windows 7 on my ssd as it is getting a bit clustered up. When in the win 7 install set-up should i format the ssd to get rid of old data?
Windows 7 is install on ssd atm.
Any help would be much appreciated.
Just use the erase that is on the windows installer, that will give you a clean windows install. You don't really want to be secure erasing SSDs as it can prematurely wear them out.
lol, yeah it will wear it out faster if you do it every week... one format won't make a real difference but either will work...
