| raVen |
Finally a nice side window without any vents as well. I can't see anything to complain about at all. Will depend on price point and quality in the end.
Price point will be 169.99$, so in UK should be cheap
That looks to be a pretty nicely designed case. Hope that Tom will be able to get a sample for review in the near future.![]()
MOAR PICTURES!
im sure it was asked but when does this go on sale? and let me just double check but wait it ahs stock support for a 140x3 rad in the roof??did he say 90mm was as thick as u can go? or was he just saing the thickness of the rad + fans... maybe a monsta rad in the roof![]()
Model Number
CA-SW810-W1
Color
All White
Material
Aluminum Mesh, Plastic, Case body: Steal
Dimensions
( W ) 235 x ( H ) 595 x ( D ) 585 mm
Motherboard Type
Micro-ATX, ATX, e-ATX, XL-ATX, SSI CEB, SSI EEB
5.25" Drive Bay
4
3.5” Drive Bay
7 ( 1 from HDD Dock)
2.5” Drive Bay
Cooling System
Front:
140 mm x2 or 120 mm x2 ( 1x 140 mm fan included )
Top:
140 mm x3 or 120 mm x3 (1x 140 mm fan included )
Rear:
140 mm fan x1 or 120 mm x1 (1x 140 mm fan included )
HDD:
140 mm x2 or 120 mm x2 (1x 140 mm fan included )
Bottom:
140 mm x2 or 120 mm x 2 (optional )
Expansion Slots
9
I/O Panel
USB 3.0 x 2, USB 2.0 x 2, 1x Mic, 1x Audio, Reset Switch, LED Switch
Power Supply Type
Standard ATX PS2 / EPS 12V
Maximum Compatibility
CPU cooler height: 195 mm
GPU card length: 375 mm (w/o fan), 350 (installed), 285 (full pivot)
http://www.frozencpu.com/products/1...ies_Radiator_-_White_23201.html?tl=g30c95s931 id rather just one thesethere based on the moar 3 rad... so you know they displace a ton of heat.![]()
Too plain looking for my liking. It doesn't have that presence that the other NZXT cases have![]()
You mean that tacky look?
