Celeron temps!
Toxcity
Good morning people! :)
I have decided im going to overclock the Celeron that I got from Sean.
So far I have it running at 2.5GHz rather than 2.1Ghz.
Just wondering what a safe temp for this chip to be at on load.
At the moment it is folding and it is running at 46oC.
Could I go up to 50oC? or further? :p
Thanks!
Rightyho! :)
Be back in a mo with results!
Whats a good voltage to stop at?
Like these things run on 1.55 defualt.. so you must be able to push them quite far.. :D
Id say a little higher than ionicals guess then and 70ish. 1.55v stock and 130nm iirc, so a little more robust than modern cpus. Had 1.9v (bios setting, real was 1.85ish) going through mine:rolleyes:
Right, Im running at 2.9ghz with a voltage of about 1.65... Is that okay?
Or should I bring the voltage down a little?
Temps are at about 50oC at load.. ;)
