Case to house a pa120.3
Mullet
All..
In my quest for uber cooling I need your help...
A friend of mine has offered to buy my case / rad off me....and I am looking at to select a new case which will likely house a dual 8800GTX and oc'd E6600...it can't be an eclipse 62 cos I know they only house a double rad and I dont really want the case to be tooo hooooge.
Max dimensions are as follows:
24cm W - 56.5cm H - 56.5 Depth
Thanks all...roll up lads/lasses.....need a helping hand asap....:wavey:
Many Lian Li's, preferablly look for a case with either a double PSU arrangement, (one on top and bottom), or one with room above the PSU... Personally I'm a big fan of rear mounting of radiators (Then you only need a 120mm in the back)
G70 is perhaps a tad on the laege side...
Anyone here own one??
Can you measure it for me and post ya findings in this thread....I have Doddsy on my back!
shamelessly C+Pd from elsewhere for the G70
Specifications
Observed Dimensions: 603 x 212 x 572mm (without feet)
Construction: Aluminum
Observed weight: 7.9kg (w/o PSU)
Mainboard: ATX up to 12" x 13" sized boards
PCI Slots: Seven
Drive Bays: six hidden 3.5”, six exposed 5.25”, two exposed 3.5"
Cooling: Three 120mm fans (front, rear, side)
Top access ports: Two USB 2.0, Firewire, mic in and audio out
Power Supply: None
Window: No
Available in silver or black anodize
if ur housing a PA 120.3 its gonna be a big case no matter what, unless u put the rad outside of the case.
