case spraying
REALLLLYYYY nice for a first coat.
and it was also a really good idea to try it out on a test panel before you do it on your actual case.
next time, you might want to elevate the item as to keep dust kick-up to a minimum
and not let the sides "attach" to the over-spray surface. and allows better edge
covering.
