Case for around £50
You wont get a decent full tower for £50 matey. Save up for abit you'll be much better off in the long run.
And that link is a midtower. If you want one that size look at the lian li pc7 or pc8
you can get teh antec 300 for that budget.
edit, must read all of thread.
I think that you will be hard pushed to find a good case to take watercooling for that price.
ok i think i might be able to push my budget to £65
edit
it doesnt have to be full tower its got to be a large mid case.
I've got a CM 690 and it's a decent case. Plenty of fan holes, PSU at the bottom makes a modular supply preferable but not essential as there is a good deal of space behind the right side panel. Keeps everything cool which was really the main requirement.
ok thanks everyone for your help, i think i will get the cm dominator nvidia edition. problem is that its oput of stock in play.com
Its got 4 fans installed at the minute, it can have another two on the bottom. They are 2* 140mm and 2*120mm
i think i will get the coolermaster one, thanks anyway
