Case fan LED's
Bullmecha
Was wondering if they make an actual blacklight LED that can be added into a case fan for UV reactive coolant dyes. I have done some searches online but have had no success.
If you're referring to 5mm UV LED's then they're common. Google comes back with loads of UK results which won't be much use to you but just search for "5mm UV LED" and you should get loads of results.
