cascade 5 GPU
First stage
compressor: LG NJ282P R-407C i will also testing a PG130XIT-4CRE 8000btu for future use on this stage
Hx: 12 plate
Danfoss tev: Tes2 00 orifice
Receiver: RLV 02 PED 77*220 V=0,88l
Condenser: 1,10kW
in line filter 1/4 flare
High pressure gauge
The copper pipe sizes used in this stage are
1/4 inch used on the expansion valve suction sensor to the suction return
5/16 compressor to the condenser and receiver
3/8 used on the run from the receiver to the expansion valve and HX suction return
1/2 used on the expansion valve to HX
Fittings
1x 5/16 straight
1x 5/16 tee
2x 3/8 tee
1x 3/8 elbow
1x 1/2 elbow
2x 3/8 flare nut
1x 1/4 flare nut
1x sevice port
second stage
compressor: PG130XIT-4CRE 8000btu
Oil separator: temprite 900
danfoss high pressure cut off KP 5
cold ice mini condenser
cold ice pressure relief valve 24 bar
High pressure gauge
spun drier/filter
Chilly type evap with one extra turn
1m braided suction return
refrigerant: R507/R23 for tests with PG130XIT-4CRE 8000btu on 1st stage
then R507/R1150 when the LG NJ282P R goes in
the unit will also have shut off hand valves located on the suction return and cap tube for easy change of evaporators and setups
there will be no case for this unit
alto i have called this a gpu cascade it will have other jobs as well
i am making it so i can just remove the evap and suction return with out having to re gas the unit
this is so i can change the function of the unit at will
i.e.: evap for single card benching all complete with suction return and insulation, a second set of evaps for sli and a third set of evaps for system benching for the ram and Northbridge
this will give me what i have wanted for some time and save me a packet on ln2 with any luck
First stage
Hx: 12 plate
Condenser: 1,10kW
High pressure gauge
Fittings
1x 5/16 straight
1x 5/16 tee
2x 3/8 tee
1x 3/8 elbow
1x 1/2 elbow
2x 3/8 flare nut
1x 1/4 flare nut
1x sevice port
second stage
High pressure gauge
spun drier/filter
