Card colour problems.
TicTac
hello, anybody know the best way to solve my problem of, i have tried to go for a white, black and abit of blue rig but my red Evga graphics card i got just spoils that a little bit. I have thought about just taking the stickers off all together but i'm just not sure how that would look. i also though about painting it all white, then i wondered whether it would be a idea to ask Evga for some blue 580 stickers(which would most likely not fit)
i'm just not sure which would be best. here is a picture of it for anyone that doesnt know what they look like.
The 580 stickers will not fit. You could try and take the stickers off but then that will most likely spoil the look of the card itself. You get nice looking and high performing aftermarket coolers out there at a good price but that may been too much work.
Yer though about that too but its a non reference card becuase its the HD and i can't even get a backplate for it
Don't worry about the colour dude. The fans will be on the bottom and you won't be able to see them anyway. If you can still see a bit of red on the outward edge, put a bit of black insulation tape to cover it slightly, making sure the tape doesn't go over the fan. This is a very simple and easy solution if you don't want to replace the cooler or take the stickers off.
