ruthless_villain
So i should be ordering the parts for my water cooling on sunday and just wanted someone with a fair bit of experience to give my loop a quick look and a bit of feedback...so for now it is just for the cpu but it will end up cooling cpu and a dual gpu set up as well.
so here are the parts:
XSPC Rasa CPU Waterblock Intel 1366, 1156, 1155, 775 : RASA Chrome £45
XSPC Dual Bay Reservoir with DDC Ultra 18W Pump (Bundle Deal) £102
Hardware Labs Black Ice® GT Xtreme Lite 360mm Triple Radiator : GTX360-LITE £50
EK CoolStream XTC 140mm Single Radiator Black : XTC 140 £38
Mayhems X1 Premix Fluid for Water Cooling 1 Litre : Blue / UV Blue £8 X3
Bitspower 1/4" Thread Barb Fitting for 7/16" ID Tubing Matt Black : BP-MBWP-C33 £2.30 X8
Masterkleer Hi-Flex 7/16" ID - 5/8" OD (11-16mm) Tubing : Clear £4 X3
PrimoChill UV Blue PVC Hose Clip for 5/8" (16mm) Outer Diameter Tubing £0.40 X8
Noctua Pro Grade Thermal Paste 1.4ml : NT-H1 £6 X1
TOTAL: £304.61 Inc VAT & P&P
Now i just wanted to know whether it is a good loop, whether it is adequate for what i want to add and if i could get away with anything less (apart from the rads)or if i could add something to make it better my max budget would be £340 But i am trying to be practical like i aint paying £15 for a extra 6mm of radiator and not paying £9 for a metre of hose etc.
thanks for any feedback given
ruthless
ruthless
