Try to use .gif .png .jpg so the file remains same quality but less in file size. Currently your screenshot is in .bmp format.
When saving the file in save dialog box in the bottom there is "save as type" choose any of the .gif .jpg .png will result in small file sizes but similar quality.
Can you also post your memory settings in bios which should look similar to below.
DRAM Configuration Settings:
DRAM Frequency Set - 200 (DRAM/FSB:1/01)
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 2.0
RAS# to CAS# delay (Trcd) - 02 Bus Clocks
Min RAS# active time (Tras) - 08 Bus Clocks
Row precharge time (Trp) - 02 Bus Clocks
Row Cycle time (Trc) - 07 Bus Clocks
Row refresh cyc time (Trfc) - 17 Bus Clocks
Row to Row delay (Trrd) - 03 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 03 Bus Clocks
Refresh Period (Tref) - 4708 Cycles
Write CAS Latency (Twcl) - Auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - Level 8
DRAM Data Drive Strength - Level 4
Max Async Latency - Auto
Read Preamble Time - Auto
IdleCycle Limit - 256 Cycles
Dynamic Counter - Disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(8 Bursts)
Thanks.
DQS Skew Value - 0
Bypass Max - 07 x
Thanks.
