can i play in 5k ? or do i need another computer?
No chance.
But you can set the resolution to 1080p or equivalent in game.
are you sure ? :(
and if i ll take the new pro version ?
i want to play at native res
edit: i don t mind using normal graphics setting, i don t need to max em out (actually i never use high settings to have less fan noise)
are you sure ? :(
What GPU does it have?
You only need to look at the many 4K reviews WYP has done on the main site to see not many can be played at 60FPS smoothly even when not maxed out, nevermind at 5K on most likely bad OpenGL ports of DX11.
I don't know about those games you listed specifically, you'd need to find performance figures for those.
radeon pro 580.
Diablo 3 and Heroes of the storm are two of the most played games in the world, so i was asking to the experts!
ok, at the end i tried it:
i can play in 5K maxed-out perfectly (i disabled AA, but it s about the same performance with and without)
perfect, i can avoid imac pro ! ! !
