CableMod Paracord cable kits are now available for CoolerMaster V-Series power supplies
Nice vid.
Guessing this is made from their ModFlex sleeving the same as the last vid you did on these ?
Yes dude - they just have a whole new range that supports the CoolerMaster Vseries PSU's now
Cooleo, I did actually get the Cablemod pack for the Corsair RMi 1000w PSU the only problem is the 24pin isn't compatible so I emailed Cablemod and they said they are coming out with the 24pin quite soon![]()
Yeah Ive been working with them on the 24 pin cable - its a bit more complicated than just pin out sadly but we should have it sorted soon.
Looking forward to ordering mine, The stock cable keeps looking at me![]()
Do you have the original whole kit still or did you send it back?
It's all plugged into the PSU minus the 24pin
The rest is back in the box in the cupboard.
Keep hold of the 24 pin and Ill facilitate you getting a replacement if youve not already sorted it
I love your face !
Would you have returned the others?
No just keep them in the box in the cupboard if I ever need them, I was simply going to buy the 24pin when it becomes available![]()
Ill see what I can do - cant promise.
