Cable sleeving
SillyOldSquid
hi everyone,
I want to sleeve some cables for my personal rig and I am not sure what sleeving and heat shrink I should get or where i should get it from.
I want good quality stuff that wont show the wire through and heat shrink that doesn't bubble when heated.
Can anyone suggest / link me to a site where i can purchase said products.
i don't know anything about cable sleeving, but we have some really good sleevers around here. do you just want to sleeve some cable for your pc? wouldn't be worth the money if you'd just do it for one project. but i bet pexon can help you out ;)
Yeah I was hoping pexon would help me his cables look good, I only need to sleeve cables for my pc for now but I know if I start sleeving I wont stop so I don't mind spending the money on getting more than I need.
Paracord sleeving looks great, is easy to do, and not very expensive. There is also a ton of colors available.
I like the idea of paracord but I already have some cables pre-sleeved with corsair style sleeving and id like something that is similar.
MDPC is a store open only purchase.. he has specific times the webstore is
available to sell...
best to make and account (anytime) and then when open can do quick business.
i opted for paracord when sleeving. deffo more color choices and terminates very
well. snags easily on installations (be careful). here in the states paracord is available
at our home improvement stores as a binding or rope... and very cheap price if
you use a lot of black..
Thanks for the help with the MDPC problem and I tend to snag stuff in my case a lot so I think if I used paracord id end up making a big mess.
I might try paracord when i build my next rig and iv improved my sleeving skills
