ChrisGlobe
Had my PC on since around 5pm yesterday (around 26 hours), been using it for most of today playing Battlefield 3, CPU around 50c with the fans and pump on their lowest settings, which was normal, when I heard a bit of a pop noise, followed by a slight smell of burning.
Didn't even wait for the PC to shut down, HWMonitor showed CPU temp about to go through the roof (80c+!) so I pulled the plug on the PC. Just tried booting again, no lights on the pump and BIOS shows CPU temp at 65c and rising; I turn the PC off again and opened it up, pump looked OK, wasn't hot to touch, but looking at the Molex power connector for it, one of the cables has come out.
Bought the H100 sealed, second hand, 3 weeks ago
Would Corsair accept an RMA for this or do I have £80-odd worth of junk plastic and metal?
