BUZZZZZZZZZZ
Jeff_s510
maybe a noob question, but can anyone tell me y whenever my video card is in use i get a loud buzzing, which gets louder the more my video card is used, through my headset? maybe a solution to the problem?
useing a gigabyte Z68X UD3 board with onboard sound, and an MSI GTX560 ti twin frozer 2
how many watts is your PSU? and is it enough. It sounds like your PSU is overloading or there may not be enough amps on the rails to deliver enough power to the sound portion of the motherboard.
750 watt ps....unknown brand.....only have a gigabyte z68x ud3, i5 2500k, gtx 560ti, 1 1.5 tb WD black hdd, 4 fans....
as i overclock my video card, the pitch of the buzz also goes up and down....the higher the oc, the higher the pitch
This tells me your PSU is not enough. It may be enough wattage wise but not amperage wise.
/sigh i kinda been wanting a new PS and case for a while now....but with school starting in sept $$$ is on the tight side....guess ill have to figure something out soon.....this antec 900 is soo annoying to work on
