Buying these only to OC!
Buying these to Over Volt?
You can over clock lots of stuff, what are you wanting to do with this rig? For gaming get a cheaper CPU and a better graphics card but your set up is good for video/photo editing and most games on max settings if that's what you are looking for.
over volting these would be a serious waste of money, i hope you mean over clock, but if you do plan on over volting them you may as well just plug them directly into the mains for the best effect or just give them away (i'll take em, lol), as they'll be the same use to you lol
I'm just trying to think of ways to overvolt a 800D. I mean, I daresay it could be done, but you're going to need a lot of volts to melt that thing :)
If you're spending that much money on a case, it might be a good idea to invest a little more into a fully modular, AX, power supply?
lol , my bad i was so excited when i wrote that OV !
yes mates , overclock .. and by theway it's going to cost around 7710 NIS = 1978 $ what do u think about the price? too much ?
Would it not be better to go with a Z77 board + a 3570k? Well, perhaps not 'better', but you'd get the same performance for less.
If its for gaming i would chose z77 mobo,cpu i5-3570k,h-100 or nh-d14 or even a beginners wc-kit from xspc.Gpu hd7950,2133mhz ram and i would choose a better case with better airflow like CM storm stryker/trooper.
Good, except for the RAM, 2133 is going to do nothing for the performance. 1600 is just fine.
