TheOrangeOne
One word - WOW! Just from that sneek peek, it looks epic mate! Can't wait to see more
It might, but you'd have a wannabe titan 980TiI could send you one if you'd like once you have your Ti and don't feel like painting it, those shrouds will most likely just sit somewhere hidden in a drawer anyway.
Tubing is done!
I do have this odd kink in the final bend though, I wonder if it is acceptable for use or not? Could a more experienced hardline bender give an opinion on this before I submerge her?
I have one more 60cm tube left so I could try one more time
Fixed that tube, filled her up, got pretty much all the air out, leak tested, booted, installed.
when you say, fixed, I hope you mean replacedthat kink could cause all kinda of problem and will definitely be a weak spot.
Yeah no worries, I've bent a new tube and replaced the kinked one ^^
That looks preeeeetty sweet!
GPU cables need some cable combs or lacing though![]()
