Ok so anything special going on here, you have probably seen many screenshots online about HOTAS solutions. I see so many with the same issue I had that I thought I would share what I did to create my own "removable" HOTAS desk mount. Not many setups really show what they did exactly.
Here is the typical dilemma we all have. Desk space used up by the HOTAS forcing the keyboard further back. In VR this is a no no, since we still need access to the keyboard for some features (excluding Voice attach and HCS packs since not everyone wants that)
Apologies if the pictures appear large. Hopefully they get resized
It isn't really comfortable either having it on the desk, Even though I have a motorised one, it would be nice to have the layout like that of what you see ingame when playing Elite Dangerous, placed around the knees or in that area.
Now im not going to spend a fortune on these Monster mounts even though they do look amazing. Since I have an adjustable desk I don't need something with height adjustment. Also at 130euros each.. I can't justify the cost.
Looked in my spare room and found a block of Oak So marked out a basic design on one half.
Pulled out the good ol' Dremel tools from Storage we love to use for PC mods and builds.
Cut out both parts. Sadly the Dremel Motosaw was no use. Its only good for softwood/plastic so had to do this with a standard saw
Clamped them together in a vice so I could sand them down and get them equal
Once they were even, I marked out the base plate that I will use to attach the HOTAS throttle/stick. Since this is just a simple solution to my needs I wasn't aiming for precision.
Found 2 acrylic panels from my old desk build I never used. Perfect for the base plate. So I measure out the inner dimensions of the HOTAS base. And marked the lines up for attaching to the side pieces.
Once I drillled the holes. I counter sunk each hole by hand. The bit didnt fit in a dremel and in a power drill I think it would be too much on soft plastic. So some finger strength and patience will be enough.
Quick test fit on side pieces. Not a bad first attempt. Remember everything has to be repeated for the other HOTAS mount.
Got thrifty and found some more plastic off cuts which would be nice to serve as a back plate adding some support. Also cut out a slot for the usb to pass through. Holes do not look like they align, because.. well they don't. My first mistake really as I measured sightly inaccurately. However the wood pulled in allowed me to get this really tight and secure. So I left it as it is.
Another test fit to make sure I don't waste time and need to back track or redo anything
Now its time to attach it to the desk itself. So using some old cheap shelf mounts made of pine, I marked some holes and drilled to attach to the desk, but also wider holes for the HOTAS mount to affix to.
My first attempt I tried putting the connectors on the inside of the HOTAS mount, but sadly this conflicted with the arms supporting my desk. I had to opt for them mounted on the outside.
Another test fit to the desk. After sitting and getting a feel for it, I found the width and placements I wanted. And yes, I know it still looks pretty tacky, and well it is, but wanted to try and clean it up somehow.
so repeated it for both sides.
And thats Diggle from Arrow in the reflection for anyone curious
Cut down the base plates so they matched the HOTAS base with no overlap
Now for the clean up. Premium black vinyl to match my desk
Base plate done
Side pieces done. One thing I wanted to do was to follow the wood grain and try to make it somewhat natural.
Little before and after shot. For a basic mount I was quite proud of myself
I considered screwing the HOTAS to the base, hence why I had drilled holes in the first attempt. But I realised the bolts needed were ugly so I settled with covering the unneeded HOTAS holes and opted for velcro instead.
Here she is attached to the desk with the grain flowing with the desk for the plates.
Attached some hooks to the back to help with routing the HOTAS cables. didnt want them handing down or in sight when im using it.
And job complete
The bolts attaching the mounts to the desk just pop out so it takes less than a minute to remove everything and have a clean desk when I need it.
Total cost if you consider everything were just offcuts... £10 for the screws and bolts. £10 for the Vinyl
edit* forgot the cost of the vinyl
So there you have it. There is no need to spend a fortune on mounts. Just make your own. Under desk mounting means I can maintain a close proximity to the keyboard which I think is necessary when using VR. You can bind all you want but its very annoying when you need to type for star systems.
Base plate done
And job complete
