slovenlyjimmy
Hi,
I'm looking for a compact and quiet tower cooler to fit my Zalman T2 Micro ATX case. (150mm max height)
Need to keep the cost down as well as I just overspent my CPU budget on a i5 2400 (was supposed to be getting a Dual core Pentium! Oops
Had looked at the Zalman CNPS5X Compact cooler, but can't find any reviews anywhere. I've also heard good things about the Arctic Cooling Freezer 13' but really need to keep to under £20 if possible.
Any ideas would be gratefully received.
Thanks
Thanks
