Bsod..... =[
glitch666
I built my computer in febuary and everything has been great untill about a week ago. I have had 4 BSODs latley and there pointing at ntoskrnl.exe as the problem. I have checked and all my drivers are up to date. I have also scanned for viruses and nothing. The thing is also that it only does it after I wake it from sleep. Can anybody help? I have included a link for my 4 minidumps.
http://dl.dropbox.com/u/90891566/BSOD.zip
Looking at your dumps I'm going to say you have possibly a serious operating system issue like corrupted files which I think is unlikely or you have a hardware fault such as bad memory, hard drive issue or power issue.
I think you should test your memory first to rule it out using Memtest86.
Actually did that last night (overnight while I was asleep) it didn't fail once.
If there was corrupted file would it do it all the time and not just after sleep??? Or is it the sleep function corrupting things?
If this is happening always after sleep it could be just a BIOS issue with your board. Does it ever BSOD when the system isn't coming out of sleep?
Nope it never has its always right after waking from sleep
Update: Just finished a MSE and Malwarebytes scan and Malwarebytes found alureon.d Rootkit. Weird thing is that I did a scan this morning and neither of them found anything. I ran rkill and tdsskiller and it was removed successfully. Ill keep testing and see if the issue still persists.
