Henrik
Hey guys...
So I have been bothered with this little problem I have for quite some time now.. For some reason my computer bluescreens every now and then when I boot in to Windows. Not every time, it seems very random. It's always just before the login screen appears. It has never happend durring the loading animation if you know what I mean...
I have my CPU oc'ed to 4.0Ghz with the RAM and FSB at 1700Mhz. So my OC is not stable you might say. But I have run LinX all memory usage 100 cycles for several times and never had a error.. (It's about 4 hours run time on my pc). Should i run it for a longer time or whats up here? I find it strange that I get bluescrren only on Boot and NEVER once I get in to Windows... I mean will a boot stress more then LinX??
What do you guys think? Am i not stable after all?
Specs:
CPU: QX9650 4.0Ghz @ 1.344V under load (1.401V idle)
XFX 790i
FSB: 1700Mhz @ 1.3V
Memory: 2x2gb Corsair Dominator 1600Mhz @ 1700Mhz 9-10-9-26
SPP: 1.35V
MCP: 1.4V
GTlVref: (mV)
-45
-45
00
00
OS: Win7 64bit on 2x Corsair F60 in Raid 0
Specs:
XFX 790i
FSB: 1700Mhz @ 1.3V
SPP: 1.35V
MCP: 1.4V
GTlVref: (mV)
-45
-45
00
00
