bsod everytime i play heroes of ae
Raging
well i got heroes of annihilated empires but everytime i start it,the first level i can get some troops but as soon as i move ahead to the other side of the bridge the comp crashes to a blue screen!,with the windows has shut down to prevent damage to your hardware - please restart..
i have tried different resolutions but that makes no difference
anyone got any ideas??
raging.
Wirelessly posted (LG Fusic: Opera/8.01 (J2ME/MIDP; Opera Mini/2.0.4719/1378; en; U; ssr))
downclock and try it again.
STOP 0x0000007F supposed to be an "UNEXPECTED_KERNEL_MODE_TRAP":eh:
ive tried all things suggested but no luck:(
edit, it wouldnt be caused by turning off write debugging info would it??
This is the official explaination, if u haven`t seen it already:
http://support.microsoft.com/kb/137539
And all the solutions, apart from switching motherboards (thanks mr helpful m$), seem to be as the guyz have mentioned.
It could be that the tests u`r running are passing as they`re not hitting the same pc-load scenario u`r pc is at whilst u`r in this game. Try some load testing stuff too, SP2004 and the like prehaps.
(I can`t see turning off the debugging thingy could be a cause)
Do other, similar genre, games work ok ?
that is the exact page i came across during my search of yahoo for the code (microsoft are ghey:rolleyes: )
i dont know if it would happen if i played a game of the same genre cause i dont usually play whatever these games are called(rts? lol)
i will try run some 3d mark 2moro but i am 99.9% it will pass a-ok cause i have played carbon and underground 2 on max settings(u2 at 1680x1050 with patch)
thanks for the reply:)
OMG WHAT PATCH. Link PLEASE.
Im tyring it tonight. Gracias!
Edit: forgot the REPS!
EDIT: IT WONT LET ME. SOMEONE REP RAGIN FOR ME PLEASE.
Happened to me when I oc'ed too far.
-Check Temps
-Re-Install Drivers & Clean w/Drivercleaner
-Download & Run Registry Mechanic
Etc Etc.
-Check Temps
Etc Etc.
what drivers?
edit: i have run reg mechanic with no change and temps are fine
I purchased this game over Steam and getting the same error. I did get it to run longer by running a Nvidia temp moniter in the background that would display the temp on screen during the game, the temp safe throughout but it still did eventually crash. I have alot of video and cpu intense games but this is the only one that gives a bsod.
