Brwmogazos Mach 2 GT setup...incomplete
Status
Not open for further replies.
Brwmogazos
ok my rig is incomplete obviously
i have bought a lian li kit too but i aint fitting it yet till i go back to greece since the mach 2 gt wont fit inside the box if i fit it :p
no cable tidying up has been done either...
Basically the gear is not gonna be changed except from the X800PRO which i sold waiting for an XT or an 6800GT or something :p
The scsi hard drive cables are a bit messy too...terminator gets in the way lol...
gonna be hiding my cables when i rebuilt it back in greece...
I have 6 cold cathodes waiting...will fit 4 of them in the pc65B
you will notice two LCD thermometers on the right side of the window...
they are stuck with double sided tape and their probes are well hidden-nice and tidy
the bottom one is fitted on the back of my compressor and the front one in the front of the compressor where the fan blows...
i experience like 8 degree drop by taking the front panel of the mach 2 GT OFF!!! thats on the back of the compressor and about 5? or more degrees in the front...
enough with the talking...lets see my incomplete rig...
Tiger 1 NB cooler which is actually dirty cheap if you know where to look for...i got mine for £8.50 and for my mate £6.50? or less !!!! the swiftek is like £30 or the Northpole!!!
The ram is cooled by 2 40mm deltas running 13/15 speed (Asus bios fan control) so they dont whine...and they cool my coolermaster ramsinks fitted all 32 of them on my OCZ 3700EB modules :)
sexy :D
nice to see your getting on well with your rig dimi, too bad u wasted your money on the X800 pro, told u to wait for the XT :D (sorry man u knew that was coming lol)
hows the ram going, you get much better performance with all those ramsinks and the fans?
well i havent tested without :p
lol
they do 242fsb @ 2.5 2 2 5 8 turbo enabled ifinite 68ms
so excluding the 2.5 timings its the tightest they can get
thats prime and memtest stable at 3.05V
they are maxxed and more voltage doesnt help..
some say cooling them helped them...dunno...
Status
