Bottom mounted psu
Dasale
Hi, I've just got new CPU, memory etc, now I'm thinking I want a new case. The one I'm looking at has a bottom mounted psu. Will this be an issue if my case sits on carpet? There is a dust filter, I'm more worried about overheating I think
You can always put spacing feet on the case, i'd be more worried about the excessive dust floor mounted cases seem to attract.
If you are going to put your case on the carpet, flip it so the fan faces upwards. Carpet not only has a lot of dust in it, but it also restricts airflow, which means you'll cook your PSU.
