[font=arial, helvetica, sans-serif]hey[/font]
[font=arial, helvetica, sans-serif]i have a problem with my pc. when the the pc has been shut down in 9-12 hours [/font][font=arial, helvetica, sans-serif]and PSU has been [/font]switch[font=arial, helvetica, sans-serif]ed off,[/font][font=arial, helvetica, sans-serif] it wont post [/font]properly [font=arial, helvetica, sans-serif]and the motherboard debug led shows a random number, but it often stops on 15, all the fans in the case, cpu fan and gpu fan is spinning and my blu-ray drive and hdd led is flashing but no boot and no image on the pc screen is shown, but if i then press the reset button it boots just fine and the pc runs fine after this. is it a bios/uefi bug or a hardware fault[/font]
[font=arial, helvetica, sans-serif]regards mikael[/font]
[font=arial, helvetica, sans-serif]my setup[/font]
mb: asus z77 Maximus v gene bios version 08.13
cpu: i7 3770k running at stock speed
gpu: Shapphire 7970 oc edition tried using driver v 12.4 and 12.6
ram: Corsair Vengeance 8gb 1600 mhz cl8 1,5v with xmp profile loaded
psu: seasonic x760w 80+ gold
sound card: asus xonar essence stx
ssd: intel ssd 520 1x120gb 1x480 gb, corsair performance 3 1x250 gb
