wotevajjjj
Hi folks
Some time ago we build a friend a new pc, it worked fine for some time but this morning it wouldn't boot.
The fans spin up for a second but then power down again. The cpu fan (connected to the mb 4pin) also spins up. There is no led post however.
This continues in a loop until we turned the psu off. CMOS has been cleared multiple times using both the button on the back and the 3pin connector thingy on the mb itself. No succes though :'(
We took apart pretty much everything and tried with another psu aswell, still doesn't work. We also removed the battery and let it rest for a while.
Once, all fans started spinning and kept spinning but no post.
Specs are:
ASRock Z77 Extreme 4
3770K
4*4gb Vengeance LP 1600
7970OC
Samsung 830 ssd
BQ Dark rock pro 2
BQ Pure Power 730w
We already contacted ASRock and Caseking but your brilliant advice is also welcome
Specs are:
3770K
7970OC
Samsung 830 ssd
BQ Dark rock pro 2
BQ Pure Power 730w
