elmonteslim
In case you're wondering, it seemed an appropriate name for this rig, as it looks a bit like Popeye's mate John Belushi:
Crosshair V formula-z;
FX9590;
2 x 7970 Matrix Platinum;
4 x 8GB 2400 Mhz Gskill TridentX;
2 x 1 TB WD Red;
2 x 128GB 840 Pro;
2 x 250GB 840 Evo;
AX860i PSU;
The three 140mm fans that came with my Air 540.
Now, it's all built, but with only one of the Matrices. The plan, is to add the second when I water-cool it, when I'll also be adding a D5 pump. I'm also in the process of RMAing the RAM, as one of the DIMMs is dead.
I think I may have been too stingy on the PSU - have you seen how much those Corsair PSUs cost? - and could do with some considered opinions.
Thank you Gentlemen - and Ladies - in anticipation of some helpful information.
FX9590;
2 x 1 TB WD Red;
2 x 128GB 840 Pro;
2 x 250GB 840 Evo;
AX860i PSU;
