After having a blue screen straight after the windows logo and being unable to fix it i did a fresh install of windows. Which seemed all good at first but then I installed the latest catalyst driver 12.4 and the same thing happened
So I restred and tried 12.3 and the same thing happened but without blue screen (windows logo, black screen, post screen) tried 12.2 and the same as 12.4. i was running on 12.3 before this problem started (after fiddling with oc settings but have cleared cmos now) just bought the witcher 2 and cant play it :'(!!!
1090T
Asrock 890fx deluxe 3
kingston hyperX 1600
msi twin frozr 3 6950
Just typed this out and had a brain wave -.-, after looking in the manual of my Mobo lastnight reading post codes i looked through my graphics card's one and see the bios switch has a quiet and performance mode (notice i had it set to quiet mode and switch it yo performance), ages ago i was messing about unlocking it to a 6970 and must have corrupted this bios (never did get it unlocked) i had switched it while the system was running and by the time i came to restart it i had forgotten all about this, so when the driver was loading it will have run into errors of some sort. God Damn I Just Formatted my drive and had some useful stuff on there!! AHHHH!H!HH!!H!... Ahh!.. argh! Flicked It Over And All Is Fine.
Thanks For The Help You Would Have Given Me lol
1090T
