Blackline Bios
Hayden
Hello all
Need some assistance with getting my new memory up to speed installed ok and recognised by the bios and whatnot but only @ 1366 Mhz
it's the Mushkin Blackline 2x2gb 996801 http://www.mushkin.com/Memory/Blackline/996801.aspx
dual kit i understand the timings need to be adjusted from default 9 9 9 24 too 9 11 9 27 and that voltage upped to 1.65
can u explain what else i need to do this is first time with bios but i seem to have the hang of it
using the GA-P55A-UD3 Mobo with i5 760 chip @ factory settings for now
thanks in advance
Hayden
If i can get to the magic 4 that would be brilliant i have the NH -D14 installed and have good temps atm, anything upwards of 3.6 would be great. wil be takings things slow and working in increments to make sure i don't go too far too fast.
Have a look at thread in the overclocking section then dude. Everything you need to know is in there including quite a few walk through threads. I get fed up with typing it all every other day. Once you have read and had a play post back with anything specific.
