Black Magic
ok, first things first, my specs:
Thermaltake 1200W PSU
AsRock P67 Extreme 4 Gen 3 Mobo
2600K Core i7 CPU
Corsair H70 CPU watercooler
4 x 4GB Vengance RAM sticks @ 1.5v 9-9-9-24 2T 1600MHz
2 GTX 580's in SLi ( currently not overclocked )
1 TB 7200rpm
120GB Chronos SSD
60GB OCZ SSD
Bios v2.10
Windows 7 64 Bit HP
ok, first things, without Toms video AND writeup guide, I would never of even attempted this. So a big thanks to you, for putting in the time & effort for both RAM & CPU setups.
Things started to go wrong, & its mainly my fault, as I took it for granted settings would of been kept, is when I updated my Bios. No naturally, things started going wrong.
I still have issues getting into Windows as when it boots, says something about boot device & I need to reset it, then itll start as normal. But anyways, that's an entirely different issue right now, (well, it might be relevant, don't know as of yet ) & that's not what im after.
Ive setup my RAM as per toms video, it was on 1333MHz, so that got changed, to the correct 1600MHz setting, as I was noticing, after a period of time, Games or even general things on the desktop started to get a bit choppy.
That's now cleared up for the most part.
Now after starting from scratch, like Tom said in his videos, & going through the overclock bit by bit, starting to make some progress.
Selecting from my Bios, under load Optimized CPU setting dropdown menu, first value was 4.0GHz.
I put in the CPU core voltage 1.10v & fixed mode.
then the settings below:
I don't even know what half of them other settings are, or IF they need changing, but anyways......
F10'd, got to the Windows Orbs, & just hung.....
rebooted, back into BIOS, & upped the voltage to 1.15.
Got into Windows, great, got about 12 seconds into the test, blue screen of death popped up, creating a memory dump file ( & I got a fair few of these somewhere ), rebooted, & upped the voltage again.
Finally got a stable voltage at 4GHz of 1.270v at around 1hr 20mins or so.
Did the above steps at 4.2GHz of 1.320v of around an hour also..... ( quite a few blue screens of death later! :lol: )
now looking through my charts, that OCCT gives, my VCore doesn't seems a nice straight line, is this normal? My CPU Load-line Calibration is at level 5 ( im guessing that's Toms equivalent of Extreme? )
Also, game I played for around 5 mins seemed a little choppy again, but ever so slightly. Is choppiness related to volts at the CPU in anyway & upping it, would cure it or is there some other setting ive not done?
Ive added some screenshots for you guys to take a look at.
Im also unsure what Long duration, short Duration, Primary plane current limit, internal PLL overvoltages are, let alone what there supposed to be set at, so some help here please guys?!
RAM settings
IF there is anything, you see, in the above screenshots that looks wrong, needs adjusting, tell me, before I go any further.
just to add, heres some graphs......
ive streamlined the graphs a little from reading another thread on here going from level 5, to level 1, but I would of thought I would have had a better response than this, considering I uploaded some pictures as well.......
.... somewhat disappointed.
the choppiness is sorted now. Still don't know what the long durations are etc, or them Ram Settings.
currently at 1.368v @ 4.4GHz. any suggesstions on lowering the voltage further with any other settings?
122 views & not a single reply. thanks guys. been over a week too.
Got no help here in this thread, so feel free to lock it.
2600K Core i7 CPU
1 TB 7200rpm
120GB Chronos SSD
60GB OCZ SSD
Bios v2.10
Windows 7 64 Bit HP
RAM settings
