Bitspower Water Tank Z-Multi 150 - Full Clear Acrylic Version
mrkatz
Hello
I have a question about this res
I want to make a config that goes from the bottom(one outlet) stright to pump.
and as an inlet to the res I want it to be at the top(with the side with the three outlets/inlets)
is this possible?
like this:
or does it have to be like this config:
and in all cases the res is sitting perpendicular to the floor
thank your for comments :)
That is exacly how I am running mine.
These reservoirs can be used any way you want, they can even be used horizontally.
but you will want to make sure the aqua-tube is on the goes-in side (slosh tube) not
the feed side. also check that aqua-tube periodically, they tend to loose some of the
plating. i moved from the chrome version, to the matte black with better results.
