ASUS P8H61 M LE USB3 REV3, ATX - 2xDDR3 1333 - 1 PCI - 1 PCIE16 - 2 PCIE (add £20.27)
ASROCK Z68 PRO 3 - 4 DDR3 2133 - INTEL HD - Z68 PRO 3 (add £45.40)
GIGABYTE GA-Z68A-D3H-B3 - 4 DDR3 2133 - USB3 - SATA6 (add £67.99)
ASUS P8Z68-V LE - Z68 - 4 D3 2200 - SATA 6G - RAID - USB3 (add £78.09)
if the cheapest one will do i'll take it. dont need any fancy pants 'i can do your laundry' motherboard![]()
im torn because now ive heard the gtx 560ti is quite loud!
The Asus P8H61M-LE USB3 would be a nice choice. It won't be necesssary to get the Z68 chipset anyway for your situation. The simpler the better right? Oh, the GTX 560 Ti is great. The nVidia cards run quieter than most of the current AMD cards. Which of the GTX 560 Ti have you chosen?
