best coolant/dye
Pugsport
Member
ive been looking around and it seems quite a few people would say go with coloured tube over adding dye to the coolant so first off id like to ask you guys what you think about using dye in the coolant? ive heard that some dyes start to gel up after a while and can clog up the system (water blocks etc)
im after a good coolant to use in my system with or with out dye which ever is the better option. ill be looking to replace the coolant every 6 months to a year or more if needed
Sorry slightly abrupt maybe. Stand by my statement though purely in the basis of his transparency of production if you're buying a liquid or dye off him you can generally find all the history on its chemistry and the testing process used. Not something you'll get easily from any other manufacturer.
