Best Air Cooling Config
Marcvs
Right I am planning on building a PC and wondered waht the bst configuration for my cooling was
TJ09 Case
I have 3x LED RED fans (48CFM each) - I would like to put 2 of those on top for looks
I also have 3 Silverstone 110CFM fans which I can use
What is my best configuration for cooling
Corsair HX PSU
8800GTX
Tuniq Tower 120 (stock fan)
i dont want it to sound like an airplane taking off but I dont mind a little noise
and I already looked at that guide but my case doesnt have fans there
The Silverstones ROCK but are really loud (they need a controler)
My best cooling was this case, 2 intake 120mm fans in front(1 Upper cooling the HDDs and 1 Lower cooling the videocards)
For exhaust 1 120mm fan in the middle and the PS 120mm on top.
The secret is keep stuff out of the way of the air and keep the airflow as straight as possible. Than you wont need 110CFM fans.(that white fan is a Silverstone 110CFM)
hehe I got 2 pcs running in this room atm, with 6+ case fans each (not including the psus etc), the fans are semi-recycled in these (don`t ask).
Sound like a plane ?
Sheessh I wish. ;)
EDIT: the inside of that case looks very smart markkleb.
Thanks Ras. When i build my thinking is "Less is More" . Since I dont have a lot of $ to work with I try to get the best from what I can dig up.
Also being the "Old Man" here noise and I just dont get along.
