Jeremy1998
I am currently modding a Corsair 800D to fit a 480 rad in the bottom. I have found that a 120mm fan can barely fit down there; we're talking like a spare cm MAYBE. My original plan was for a Black Ice SR-1 480, but seeing that space down there, the SR-1 can not fit... It is simply too wide beyond the fans.
I have measured, and I can fit a radiator up to 60mm thick, roughly. The fans I will be using are Bitfenix Spectre Pro 120mm LED fans, so I probably need some sort of a low FPI. What would the best radiator be for me that is not much wider than a fan?
(By the radiator is wider, I mean that a Black Ice SR-1 rad has angles on the side, so the radiator is like 130-140mm wide, as opposed to 120mm wide. I need a ~120mm wide rad.)
