I have my new build in mind but im stuck as to which motherboard to go for and would like some suggestions on what people like and/or think is the best (as these are not always the same)
The only criteria I have for it are
Intel 1155 socket (either 2500K or 2600K will be used depending on budget)
SSD used for OS drive (SATA-600)
Around £200 (will go a bit higher if it is really worth it)
Some that I like are:
ASRock Fatal1ty Z68 Pro
Asus P8P67 WS Revolution
ASRock Z68 EXTREME7
Asus SABERTOOTH P67
Any ideas on best choice or any other boards that are around the same price with good specs and look half decent?
ASRock Z68 EXTREME7
Asus SABERTOOTH P67
