Computer crazy
Hi,
I am wondering if the Be Quiet Shadow wings are compatible with radiators such as the XSPC RX series. I am aware that the fans use a push pin style mounting system and I am wondering if this can be removed to allow the fans to be used with normal M3's for use on radiators or if there is another way of mounting them to the radiator?
Also these fans seem extremely quiet but I would like some first hand opinions are they silent at 12v and is the build quality good?
Cheers in advance.
Cheers in advance.
