AX750 cpu not going into mobo
grandpatzer
so the left cable does not click into motherboard regardless how much force I use.
it is 2-5mm from going inside it, something to worry about?
you can click on picture for bigger picture
Looks to me like that fan cable is in the way.
Edit: Also, have you tried it the other way around? Not used an AX PSU, but might the two ends have different length connectors?
Is the cpu power long enough? You could take the 8pin cpu power back out from behind the mobo tray and try and connect it with it going over the mobo itself. Maybe its just that little bit short
